1769 HSC/B Underflow error
glenncovington
Apr 2002
Gloucester, VA
303
Hello all. I have an issue that keeps plaguing me. The system has a 1769-L24ER processor and a 1769 HSC card. I am using CH.0 for tracking product on a conveyor belt with an encoder. The HSC card is set up ring counter. Occasionally I get an Overflow or Underflow alarm that is a pain to get reset. Max count is set to 2147483640 but in code I reset count to 0 at a count of 900000000. Not sure of conditions that set the alarm condition but always seems related to a maintenance situation on the equipment.
This is most likely an issue of configuration that I missed a step. It seems like I should be able to reset the counter and GenErr alarm bit programmatically but that has not worked.
Any advice is appreciated. I usually have a dance of manually setting resetEn bit and then cycling power.
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,371
Here is my hail Mary pass I have a wheel that produces 33 pulses per revolution. The RPM of that wheel will be anywhere from 25.21 to 62.7 Pulses...
4,703
Hello, Im trying to use a 1769 HSC card to get the RPM of a single channel encoder at 60ppr. Ive read the other threads of people have similar...
1,694
Flashing Red OK Status indicator : Rockwell Automation Publication 1769-UM006E-EN-P - July 2013 Table 23 - Configuration Error Codes pg 117...
2,178
Hi All, Sorry if this has already been asked but I could not find more details for this type of application. I have not used a 1769-HSC/B module...
1,561
