1769 HSC Rate in RPM
Riiska
Jul 2020
CT
Hello, Im trying to use a 1769 HSC card to get the RPM of a single channel encoder at 60ppr. Ive read the other threads of people have similar issues and tried there suggestions but the "current.rate" never seems to work. The current.count is working fine but the current rate will jump up to 100 or 200 if i spin the encoder fast but if i'm spinning it slow it stays a zero.
Any help would be much appriciated.
Here is my hail Mary pass I have a wheel that produces 33 pulses per revolution. The RPM of that wheel will be anywhere from 25.21 to 62.7 Pulses...
4,704
Hey Folks. A little issue today with a 1769-HSC. I'm using a 1024 PPR encoder. Connected to a 1769-HSC Card. On my test bench the card is in an...
17
5,484
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,373
Hello all. I have an issue that keeps plaguing me. The system has a 1769-L24ER processor and a 1769 HSC card. I am using CH.0 for tracking...
1,468
Flashing Red OK Status indicator : Rockwell Automation Publication 1769-UM006E-EN-P - July 2013 Table 23 - Configuration Error Codes pg 117...
2,179
