r_mclinn
Hello all,
I have a question concerning the differences between two A-B controllers.
I used a 1769-L32E to test a project. The project consists of a Keyence 3D laser sensor reading the profile of a weld, the output from this sensor will be fed to a Fanuc robot. The plc was used because the Keyence sensor is 32 bit and the Fanuc robot is 16 bit. Basically I took the information from the sensor did a little math to convert from a DINT to an INT that the robot could read. This all worked very well in testing. For the project however we used a 1769-L23EQB1B, I can still see the data from the sensor and the data sent to the robot, but the robot cannot see the data. Is there something different between the two controllers that would cause one to map data differently from the other? I used the same program the only change was the controller. Any ideas?
Thank you,
Robert
Thank you,
Robert
