1783-NATR IP Address Translation Tab
nmk34
Apr 2019
texas
80
I have this module connected to my laptop at my desk.
laptop ip: 192.168.10.127
laptop connected to port1 at the 1783-NATR:confused:
1783-NATR Public IP: 10.50.10.30
1783-NATR Gateway ip: 10.50.10.1
1783-NATR private IP: 192.168.10.193
when I try to create a new rule, with the ip addresses above, private and public, I get an error " invalid public ip", why?
sorry, i found my mistake when i setup the rule.
i was using the assigned ip addresses for the private and public ports of the 1783NATR. i should have used different addresses other than those.
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
258
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
446
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
565
Hello, I'm seeing some interesting behavior with my NATR connections on FTLinx. 2 separate cases are showing the same problem: The first NATR...
628
Hello, I have been trying to set up a NATR with 3 connections, I am able to ping the public IP of the NATR itself off of my network, but nothing...
694
