1783-natr to micrologix 1400 ?
LSPort
Dec 2016
uk
29
Just setting up a 1783-NATR, i have got it to work to navigate and go online to 1769-L32E.
But am i have issues getting to a Micrologix 1766 L32BWA Series A.
Does the NATR work with ML 1400's or is it just me ?
It's not you, it's the NAT device configuration. It will definitely work with both CompactLogix and MicroLogix devices.
Double-check the IP, Subnet Mask, and Default Gateway values on both controllers.
thanks for the reply, you were correct.
I had set the second subnet on the ML1400 gateway address.
I was using the little screen on the processor and goofed the config...
I obviously need my glasses more than i thought..
Another question, do you know if can use the same device with a mitsubishi q series for the translation function. ?
I am using 1783-NATR with L32E CPU. CPU has IP address of 192.168.0.149, subnet 255.255.255.0. CPU is in private network. My NATR modules private network IP address is 192.168.0.152 subnet 255.255.255.0. and public network IP address is 172.25.70.107 and subnet is 255.255.248.0. on public network side my L32E CPU mapped with IP address of 172.25.70.108 in network address translation rules. but still my PLC was not ping on public side. IP address of NATR module was ping on public side.
So please give me solution.
You need to start another thread. This one is two years old and most people won't even look at it.
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
248
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
434
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
556
Hello, I'm seeing some interesting behavior with my NATR connections on FTLinx. 2 separate cases are showing the same problem: The first NATR...
622
Hello, I have been trying to set up a NATR with 3 connections, I am able to ping the public IP of the NATR itself off of my network, but nothing...
680
