1794 0816 Output Module still flashing
The G Man
Mar 2008
Atlanta Georgia
17
Hi everyone,
I have an output module that is blinking outputs 6 and 7 even when I take the wires out from the terminals. I thought it was the output module, I changed it and still had the same problem. My only other thought is that it is the relay base. Has anyone experienced this if you have please help it is driving me crazy.
G
Could you please confirm the part number
Is this is an Allen Bradley module ?
You quote 1794 is that a flex I/O module ?
Next the O816 should it be an OB16 or an OE16 ?
Yup -- output lights will still blink if they are programmed to be blinking even though the output wires are disconnected.
I dont understand, if the outputs are programmed tobe coming on then the LED's will blink wont they !
The LED is usually BEFORE the final output stage of the electronics so will operate regardless of the power connected to the output ?
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
172
I'm sure this question has been posted a thousand times on here but for me it was even funnier when I got to ask Rockwell / AB directly. My...
170
Hello, a customer i support has DH+ RIO racks all over the plant. they use 1794-asb modules. today they had a rack fault out and go unresponsive...
657
I have to configure new 1794-ADN Series C in my devicenet network. I have downloaded the EDS File and registered it. But while configuration in...
1,053
Hi Newbie here :yeah: Can one of you experts help me with setting up a simple BTR and BTW to just test 4 analogue inputs 4-20ma (1974-if4i)...
1,001
