22,5mm ket switch with ejecting key
rQx
Oct 2010
Trelleborg
1,051
I found out that Allen Bradley had a key switch with a ejecting key function, the sensEject. But it is discontinued. I've failed to google another solution, does anyone know of a brand that has this? Or another solution for avoiding people letting the key stay in the switch.
/Tim
A hinged cover over the switch that won't close with the key in and a proxy sensor to know it is closed.
Sort of like the ARM cover over a jet fighter FIRE button
Hi, I may have dreamt but I could have sworn that I have seen a 22,5mm hole mounted code device somewhere. Main objective is to only be able to...
1,458
Waterproof Industrial 3.5mm Speaker for use with ThinClient and FTView Alarm&Events Hello, Elsewhere at this site the thinclients (Dynics BTMM)...
874
I thought I could easily find a previous thread where someone had used an adapter to mount an S7-300 CPU on a standrd 35 mm DIN rail, in stead of...
5,680
Hi Everybody, newbie here with PLCs, using a B&R plc. I'm playing with a printer and its tcp socket communication. Connection works fine if...
156
It's been over a decade since Bosch Rexroth announced their SIL2 joystick for vehicles using multiple axes and interfacing with CAN/J1939...
116
