NetNathan
Would you ground 1 side of a 220V control circuit to make a neutral?
I am doing a 110V control panel that has 3 pumps running at 480V 3 phase and 1 device that runs on 220V single phase. The plug calls for:
200-240VAC 50/60HZ
Pin1 = Phase 1 - L1
Pin2 = Neutral - N
Pin3 = Earth Ground - PE
I had intended on floating the 240V from a 1 phase 3KVA 480/240V Transformer. Is this a no-no??
200-240VAC 50/60HZ
Pin1 = Phase 1 - L1
Pin2 = Neutral - N
