22mm Encoder w/ Knob?
ndzied1
Aug 2002
Chicago, Illinois
2,857
Does anyone know of someone makes an encoder that fits in the opening for a 22mm pushbutton? Something with low resolution but A & B channels so we can tell direction for trimming a signal?
That seems like an odd way to trim a signal....unless you're looking for infinite trim. ? Otherwise use an analog POT. If infinite trim just use two pushbuttons...up/down...create your own pulse train on the buttons being held down within the PLC.
The customer wanted something rotary and right now we have a pot but there is a catch.
On the screen in the panel, the customer can select one of 14 different values to 'trim'. All of these have a manual entry but they also want the operator to be able to make slight adjustments up and down using a rotary knob. It's easier and more tactile this way so they can watch the process without worrying if they are touching the right place on the screen.
They are only adjusting one at a time which is also selected on the screen.
The dilemma comes in when they change from one parameter to another. What if they have moved the pot all the way to one end on the previous adjustment and then need to adjust the new parameter in that same direction? I thought when they change we'd throw up a pop up box that asks them to center the pot but if I had a simple rotary encoder that was slow enough to be read by standard inputs then I'm in like Flynn. Even if I need to get an encoder card I'd be ok because everything is on slice I/O. There are 8 of these panels on the system and they are already built so the room I have is the space for a 22mm pushbutton.
I have used an encoder to control the speed of a machine. When using an encoder, you can make the signal go to zero and start over every time the machine stops.
I have a customer who has requested a keyed 22MM potentiometer on his enclosure to provide speed reference for the VFD. Basically to prevent...
21
4,755
I'm looking for a spring loaded flip down cover for a 22mm push button. Preferably, one I can add to anyone's PB, though I'd be happy with an...
1,669
I am trying to add pushbuttons to my plant electrical standard and we have 22mm and 30mm. They must be ab so i wanted to get opinions on the...
4,816
I'm wondering if anyone knows of, or has used, or has seen a trapped key system where the keyswitch part of it is used in a 'standard' 22mm push...
21
5,362
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
307
