Orn Jonsson
Is there any problem with connecting two or more 24V DC power supplies in parallel to get more Amps? I have one 40A supply on a large machine running 20 servo valves plus a bunch of I/O. After 16 years in service it appears as if the machine is now drawing more than the 960 Watts available and faults the SOLA HD power supply on a start up. If I disconnect two or more of the servo valves during power up, the supply holds ok, and then we bring those two valves back on line. So this problem only happens on a start-up. Probably inrush related. Current power supply is about 5 years old.
I was thinking of throwing a small 5 AMP sola PS in parallel with the 40Amp one.
Please advice if you have time.
