Power Supplies
Engineer_UA
Oct 2016
California
43
Hey Guys,
Can anyone recommend a P/N for 48VDC input, 12VDC output power supply. I tried looking up Phoenix Contact/ RHINO, and wasn't able to find a product with the above voltage inputs/outputs.
Thanks!
EE
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
112
is this possible? i have a customer has has a large factory, he has 2 x 800amp supplies coming into the site and would like to switch between...
922
Is there any problem with connecting two or more 24V DC power supplies in parallel to get more Amps? I have one 40A supply on a large machine...
21
7,395
Hi all, I was hoping someone could tell me if there's an advantage between using PULS or AB power supplies that are rated for SELV and PELV? I...
1,990
I have an application where I need around 60 Amps of 24V. Most 24V PS go up to 40A, so I need to be able to add them in parallel. Puls power...
36
10,380
