3 Atlas Copco Air compressors- M580 PLC
akash11132
Jun 2017
Sydney
45
Hi All,
I am programming M580 PLC to start/stop 3 Atlas copco Air compressors (2 duty/1 standby) remotely via master regulator ES4i. All 3 air comprssors are connected to the master controller ES4i module.
I have planned to use 2 Digital Outputs(1 for remote start/ 1 for remote stop) to control master regulator ES4i module. The ES4i master module does the duty cycling between compressors. There are 15 Digital Inputs( 5 DI for each compressor) that are to be extracted from the master regulator ES4i module to the M580 PLC.
Has anyone done similar kind of comms between PLC and Atlas Copco air compressor. If so, what would be the ideal Comm protocol to be used for this set up. Many thanks in advance.
Regards,
Akash
It was hard trying to find the software ECT for this drive. Finally, I found it but since it is very old it is not intuitive at all. Is there a...
108
Hi Guys, I'm looking for a download for the ToolsTalk software for atlas copco controllers (power focus). The laptop that had it died and of...
3,168
Hi I´ve been looking around the web trying to find programming software for Atlas Copco DMC drive series..(Example: DMC 50720) This far I...
2,508
Wizards, Has anyone used the wireless torque gun set up from Atlas Copco? I was asked to see if it would be an improvement to change over to...
1,297
I'm most likely out of luck here, but I'll give it a shot to ask... Does anyone have the following software? PAM Tools SAM Tools ProMotion...
20
6,954
