3 phase motorchoice...
userxyz
May 2002
any
2,768
I have a little project, designing a sawing machine...
Problem is, I don't know what motor I should use.
I have calculated that I need 2,286 N (Torque) (each tooth)
I have calculated a speed of 485 rad/s. (axe running 4620 rpm)
So I calculated the Power that I need: P = W x T = 485 x 2,286 N = 1109 W
I know that the diameter of the saw is 165mm (= d2)
I know that n = 4620 rpm.
n1/n2 = d1/d2
so I choose a motor of 1,5kW and a speed of 3000 rpm.
d1 = (n1 x d2) / n2 = (3000 x 0,165m)/4620 = 107 mm (diameter on the motorside).
What I don't understand is, I've calculated a needed power of 1,1 kW and chosen a motor of 1,5kW, but if I choose a motor of 1,5 kW that has 1400 rpm or one with 3000 rpm, I know that it needs 1,1 kW to make it work on the saw side, but the motor does not has to be 1,1kW, can be less or more, depending on the diameters that are calculated, or am I wrong ?
What motor is best for a sawing machine... a standard 1400 rpm 1,5kW motor, or one with 3000 rpm ?
Is this a circular saw application ?
We need a picture please - how is the motor connected to the blade, what is the duty cyce, how about an allowance for friction between the blade and the material being cut.
You have some fundamental problems.
First, horsepower is horsepower everywhere in the system, and if you change speed the torque will change but the horsepower remains constant.
Second, As I recall my metric Newton is force, and Newton-meter is torque. Therefore, your calculations can't be correct.
hi
I wrote N, should have been Nm
BEREKENING VAN HET VERMOGEN + KEUZE ELEKTRO-MOTOR
  • Hoeksnelheid (W):
v = s / t
s = π * d = 1 tr
v = π * d * n
De gewenste snijsnelheid = 40 m/s
Zaagblad ø = 165 mm of 0,165 m
40 m/s = π * 0,165m * n
n = 40 / (π * 0,165 m) = 77,22 omw/s => *60 = 4620 omw/min
W = 2 * π * n = 2 * π * 77,22 omw/s = 485 rad/s
  • Koppel (T):
Fx => cos 30º = Fx / 32 N => Fx = 32 N * cos 30º = 27,71 N
Fy => sin 30º = Fy / 32 N => Fy = 32 N * sin 30º = 16 N
De loodrechte Fy zal geen moment veroorzaken =>
T = F * a => T = Fx * a => T = 27,71 N * 0,165/2 = 2,286 Nm
The horsepower remains constant, okay, thanks
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
234
What would happen if you ran a 60Hz Single Phase Motor on 50Hz supply?
555
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,393
We have an existing VSD where a three phase circuit breaker feeds the drive, and two phases also tee off to a contactor, which is energised to...
1,509
Hello all... I'm looking for a 480v 3ø 25+ amp Solid State Relay to replace a mechanical one beating itself to death keeping temp in a heating...
2,002
