300 Micro list / message question.
Mark_H
Jul 2004
48
I'm using a 300 micro panel view with a ML1200.
I'm not sure if I can do it but I would like to have a list where I can have the user scroll up and down the list, and each line would be like a message display tied to it's certain bit.
For instance the full list would display like this:
Switch 1 ok
Switch 2 ok
Switch 3 ok
Check Switch 4
Switch 5 ok
Switch 6 ok
Check Switch 7
Switch 20 ok
Ideally I would prefer to display only the lines that needed the attention, but I fear it would take more time to implement then it is worth, and I have a feeling they are only going to come get me anyway...
Have a look at the Alarm List. Depending on how you define "needs attention", you may need to create a separate bit in your PLC and have that be the Alarm trigger . . .
Marc
Thanks for the suggestion, I called AB Tech Support this morning and they told me what I wanted to do was not possible on this platform. I would have to go to a Panel View Plus. I'll just use the individual message objects and spread them out over a couple of screens.
Thanks again.
You could write your own logic for a scrolling ST file.
Just use a Bit assigned to an UP arrow, and call an integer, representing a phrase in the PV.
For some of these more intuitive needs you have to be more creative.
In comparing a PV300 to even the most basic PV+, you are talking thousands. (CAD).
In the old school, and I am not old...but 34, we actually had to write the logic. It would be nice to have everything pre-developed....but for $400.00 plus the PV software, you can't ask for anything better for the money. (and reliable).
I have integrated many of the 300 series, they work well...but watch out for passwords on the micro!
Is this the clock battery flat? Does anyone know how to remove the back of the PV 300 micro. Is it possible to replace this battery. AB says it's...
1,164
I am reading and writing to a Kinetix 300 using messgae instructions on the AB Micro 820 over Ethernet. I did this successfully using a ML 1100 a...
1,297
I have an opportunity to get some more experience replacing an old Panelview 300 Micro. I'd like to hear any advice you have about it. I suspect...
3,300
I lost the manual for this machine built in 2003 and need to put it back together. I have the Micrologix 1200 and PanelView 300 Micro programs...
1,782
I am tying to download application software to a fresh out of the box PV 300 Micro. The first hitch is a prompt that I am running v4.1xx RSLinx...
1,149
