Kinetix 300 - Micro 820 communication lag time
lurby
Mar 2005
32
I am reading and writing to a Kinetix 300 using messgae instructions on the AB Micro 820 over Ethernet. I did this successfully using a ML 1100 a while back but now my distributor is pushing me towards the Micro 820 because the ML1100 is short lived.
I am using the UDFB's provided by AB and I can get it all to work but I seem to be experiencing quite a bit of lag. For example I have set up a JOG function which is basically a velocity move. Press the button, enable the drive, set the speed and go. Release the button and it stops. The drive then disables. It seems to take a long time between telling the drive to enable and then getting the signal back that I am indeed enabled before it will move. It does eventually go but it takes a good 5-10 seconds....
Once it moves and I release the button it stops. If I let it disable the timing issue starts all over again. If I press the button again quickly before it has had a chance to disable it takes off immediately.
I can view the drive status using the MotionView software. The drive is indeed enabling almost immediately. It's just that the PLC does not know it yet.
Is there a time setting for the communication back and forth? Could there be something else dragging me down?
Thanks in advance
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
144
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
218
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
99
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
427
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
526
