317-6tk13-0ab0 memory card eprom error CPU 317T-2 DP,
we did
The “object has already been deleted “
You get that by just pressing the accessible nodes icon?
What happens if you insert the original mmc in the pg’s prommer?
And then press the icon to read the eprom
What happens?
What happens?
we get this empty card
Without any (no Simatic manager project or program in a memory card) program….
You’re out of luck that I can see. Maybe someone else here has an idea
i hope so .....anyone experience with this
CPU 317T-2 DP​
and a project or something :)
found solution ourself .. simatic manager 5.1 can not communicate with 8mb card. we installed 5.4 and could load new firmware .
put memory card back and working again
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
303
Hi, We have ControlLogix installed at my plant with Flex IOs communicating with controller through ControlNet module. Yesterday, while controller...
506
I am working on an older system where they are switching out the weigh in motion scale on a conveyor system from an AP Dataweigh to a Mettler...
1,285
Hi all, Need your recommendation my issue below: I have CPU 317 with 4 racks and 5 siemens drives All of them connected on DP out of the CPU...
1,306
I almost have a complete, basic setup for a shop/learning fixture. I've got a used CPU317-2 DP, a G120C, and some purple hose. I'd like to add...
20
5,425
