4-20ma FLOWMETER NEED TO TOTALIZE GPM
Average and add average and add..........
Average the Flow Every Minute (10-20 samples depending on the accuracy you want) then put the numbe aside (in reg.) a minute later you will have another average flow for the minute which just passed. Add that to the last nuber etc.......
O Jonsson
Just wondering if it is possible to wire in a Cynergy UF08B100 Flowmeter into an Allen Bradley 1734-IE4C. I have tried every way I can think of...
3,234
Hi, I have a 4-20mA Electromagnetic Flow meter which is externally powered. I have a 24VDC supply powering the meter (which is powering up...
1,769
Hi all, I'm connecting several 4-20mA sensors together in parallel (only one shown below) The enclosure is ABS plastic with metal backplate DAQ...
275
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
277
What's your go to 4-20ma isolator. I've got some 4 wire 4-20ma from several flow meters and scales that I would like to isolate before it gets to...
1,697
