Handcraftedsince87
Greetings,
So this seems like it should be pretty simple, but I'm guessing there's something basic that I'm missing, and am hoping you guys could help me out with it. We have a flow meter. That flow meter used to control 2 chart recorders and a PLC input all on the same loop. We ended up needing a new steam flow meter and they recommended we seperate the loops. Now the steam meter goes to an analog input (works great) on a Logix5000 plc, and from there we have 2 analog outputs. One to a chart recorder, and one to a computer that monitors our opacity and Co2 and what not. I can't seem to get any output on the chart recorder channel when I measure, or on the chart itself. I've tried switching channels to no avail.
On the ESP cpu, it's outputing, but I don't thing it's working correctly. It only outputs whatever I set my low signal to in the properties for the card. Everything is set on 4-20ma, and with a 0-240 scale. To move the floating number I used a "move" instruction to move the data from the steam fow input to the correct output channel. It's an OF8 AB analog output card, and I did double check it's wired up to the current output and not voltage.
Like I said, Im sure I'm missing something simple and would appreciate any help I could get pointing me in the right direction.
Thanks in advance!
Cheers
Thanks in advance!
Cheers
