4 input -1 output relay / transistor
kiwisoundguy
May 2011
Glasgow
18
Hi Guys,l
I was after a little help,
I have a 4 sensors that can trigger alarms when 'x' value is exceeded. I would like to have a siren / beacon alarm to show when this value has been exceed. But I would only like 1 alarm for all 4.
I've attached an example of the circuit. The supply voltage will be 12 or 24vdc. I plan to have the 4 independet LED as per the circuit diagram, but I wish to somehow colminate all the alarm outputs into one after the LED to feed a audial / visual alarm via a relay or transistor.
Any ideas?
Thanks in advance for your help!!
No Problem.
Just connect another wire to Alm1 followed by a diode IN4001.
Do the same for all the other 3 alarms.
After the diodes, just connect all the wires together. The output from this wire can be connected to a relay, buz etc.
How can I use 1 button and 1 light using only b3
253
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
349
Hi i would like to ask! Im using Omron CP1E PLC May i know how to use one input to trigger two outputs alternatively? Meaning press X0 on, Y0...
401
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,418
Hello! I have a FB with inputs, outputs and inputs-outputs. The build finishes with error, if one of input-output isn't connected. I need an extra...
442
