4 pole triple throw?
John Morris
Sep 2015
San Antonio
690
Does anyone know of a relay with a neutral or center position. (non latching)
Google hasn't heard of it.....or.......I am not asking the question correctly
(which is usually the case)
Any and all is appreciated.
Thank you
I suspect you're trying to stop the LA mid-stroke?
I would just do this with a pair of DPDT's. I've never come across a DPDT relay with a center off. No way you can do this with even ice cube relays?
That first link is exactly how I wire my LA's when I need to stop mid-stroke (I use a LOT of LA's).
Keep in mind with that second link, those are 5v coils.
If size is that important and you can't fit 2 socketed relays, you could always grab a pair of these;
http://www.mouser.com/ProductDetail...GAEpiMZZMtGt%2bn33CgIP42LcsHf9RTf3zuZtMtXYfM=
And solder them on a PCB protoboard. That would get you 24v coils and a slightly smaller package, at the expense of some labor.
Have you considered mercury contactors?
we used them a lot in the automotive testing industry.
no more welded relay contacts.
also, ab 100c series - don't know if this is what you are looking for.
you would have to look at the specs in regards to 24 vdc
james
Relays operate with solenoid coils, which are binary devices, one state or another state. You are asking for a ternary device, they do not exist in the relay world.
RH2B-UAC110-120V
There is no terrestrial way around it. 2 DPDT relays.
hd_coop, had a long conversation with Crydom today. They didn't seem to know those existed.
Thank you all for your time and input.
Hello Everyone! Short and simple questions, I have one PLC output, that I want to wire to 10 different devices. Does anyone know of a relay that...
2,411
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,831
Hi I have an IEC motor 4pole motor 50Hz 5.5kw. It is stamped with 1540rpm. Is this even possible for a 4-pole motor?
3,327
I apologize in advance if this is off-topic, but I really need to understand what's going on... While doing some renovations, it was found...
20
5,575
I am designing a machine for use in the European Union. The machine will include a Ropex heat seal controller that will receive a 230VAC single...
40
7,354
