4 pole triple throw?
In old telephone systems and in pinball machines they did exist.
if it is only to stop i would use a simple relays, as 9Amp is not very much a small H bridge is a good control thing have a look at racing cars, as they use 40 Amp controllers in very small packages.
Isn't this similar to a 3-phase reversing motor contactor set-up ?
Two independent contactors, BUT, with a mechanical interlock between them in case one contactor has its contacts welded shut...
I would have thought the same principle needs to be applied here.
Or use one spdt relay as the direction relay and another relay (or SSR) as the on/off. The spdt relay can't be in both positions at one time.
Open/Close
ON/OFF |------|/|
Open/Close
ON/OFF |------|/|
Best suggestion yet... and the direction relay needn't switch the energisation surge current, since it will already be seated. And I would control it so the direction relay can't be energised or de-energised while the main relay is on.
But I'm sure you meant dpst - it's the dt part that the OP is having troubles finding.
The direction relay just needs to be single pole double throw. The on/off relay just needs to be single pole single throw. I use a solid state relay for this since it will be pulsed on/off a lot.
Hello Everyone! Short and simple questions, I have one PLC output, that I want to wire to 10 different devices. Does anyone know of a relay that...
2,411
We are installing 20 foot direct burial fiberglass light poles, and we are mounting speakers for a pa system on the pole about 12 feet up. Can the...
1,831
Hi I have an IEC motor 4pole motor 50Hz 5.5kw. It is stamped with 1540rpm. Is this even possible for a 4-pole motor?
3,327
I apologize in advance if this is off-topic, but I really need to understand what's going on... While doing some renovations, it was found...
20
5,575
I am designing a machine for use in the European Union. The machine will include a Ropex heat seal controller that will receive a 230VAC single...
40
7,354
