4 pump control
irfan22in
Aug 2002
FRANCE
hi all
i have posted a query long back for a code to control 5 pumps .
i am posting a code which i think is compact and good for the control as mentioned below.
contrl here is for 4 pumps and pumps should come ON in sequence as per operator selection.
i.e if operator selcts 4231 the 4 should be ON first then 2 then 3 then 1.
if operator selects 1324 the pump ON sequence should be 1 3 24 in the order.
I took a quick look, and to be honest, once I saw the lack of ladder documentation, I just closed it.
I would hate to be the person that had to maintain this code. I suspect that even you will have difficulty following the code six months from now.
No offense intended, but I am a firm believer in comments for everything.
ken,
well i understand that attached files does not have any comments attateched to the rungs.
i will post another file with comments attached to it soo.
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
118
Hi everyone, I am a newbie and I have trouble in the control sequence. I have a system with 4 pumps. The required: Ex: Push a button to start in...
21
2,783
Hi there, We have a system at a water treatment plant where large raw water tanks feed into the plant that's all on the same level. At high tank...
18
3,801
I am at a loss... I have a pasteurizing system that i need to control product temperature with the speed of the product pump. I currently have a...
2,611
I am controlling a very tight window in a 8 foot sump. My low level to keep from cavitating the pump is 44” and my high level is 55”. The problem...
2,086
