480 receptacle / enet
doug2
Dec 2006
California
181
I have multiple pump stations that will have a 480 receptacle and a enet rj45 receptecale. Has anyone found a unit like this?
I have not seen any that combine both. We have used 480VAC receptacles from Hubbel with good success in a washdown environment. They also make some pretty robust looking ethernet junction boxes and connectors.
Paul
ya i was thinking about using a hubbel receptacle and a small ss box with a "grace port" for the ethernet. I was just hoping to find a combo unit.
thanks
Hello all, I have a question and would like a few opinions if possible. 5x 480 outlets control 5 machine. I want to run them through a contactor...
189
I will be adding contact relays and current switches to a control panel that is majority 120VAC and some 480 3-phase. The coil voltage is 24 VDC...
2,661
Hi all Where can i find this transformer ? Pri 480 v 3x 0.12 A Sec 400 v 3x 0.12 A 3 phase Type DTS 80 50/60 Hz
3,606
Wizards, I have been gone from my plant for a while and upon returning I have two, 480vac-24vdc power supplies on my desk with DEAD written on...
2,285
Okay. On a semi-impulse, I scored one of these units relatively inexpensively. A development rig upgrade over my L320ERM: 5MB user memory, 120...
1,464
