Dan, the big selling point of floating delta 480VAC is that it will tolerate one ground fault without stopping your operations or clearing any fuses or breakers. Nevermind that someone might get killed in the meantime.
Of course, the really laughable part of that selling job is that, at the next downtime, you will go out and find the ground and clear it. Yah, right! That ground will stay there until the next ground fault occurs and shuts you down. Then, the maintenance budget will kick in and, well, lookie here! There's two grounds, not just one!
Wonder where that came from? And, is that maybe why that buzzer and those yellow lights are on in the substation? And have been on for months! Good grief! I see that all the time because AC drives and especially DC drives do not work properly on corner grounded delta power. So, I check it before I start up a new system and, if there is a corner ground, I report it and question it. You should see the blank stares I get. A corner ground? Really? What is that? Do we have to fix it now?!!!
Well, you get the picture. Sorry for the rant!
