5/03 comm ?
Terry Boblitt
Jan 2006
Willisburg, Ky.
119
I'm trying to go on line with a 5/03. Right mow ch 1 is connected to a 1747-AIC & it's connected to a 1761-NET-AIC. When I plug into ch. 0 and try to see the processor in RSLinx it's not there there. Also I've tried to communicate to ch. 1 using a PCMK card. What am I doing wrong ??
Thanks Terry
The serial port on your SLC5/03 ( Channel 0) defaults at DF1 Full duplex
protocol. Are you using the RS232 DF1 devices driver in RSLinx? Also are you using a null-modem cable? Channel 0 can be configured for DH485, if you have the offline file check to see how the port is configured.
Tell us how you have your PCMK card configured baud rates must match and node addresses must be different then the SLC. What cable are you using?
Have you tried to setup RSLinx's RS232 DF1 Devices driver manually to match the controllers configuration.
Note the baud rate, error detection
I think RSLinx will just tell you it can't communicate but not a reason why.
Try to set RSLinx up manually.
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
54
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
16
537
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
146
Guys need a bit of help getting the instance correct for a 22comme with a PF40P. Trying to get 2 things first is the drive current amp draw...
97
I have 3 new PowerFlex 7000 VFD's. Rockwell was out to do some checking before startup. These are part of a larger electrical project. I gave the...
341
