5/04 Remote rack NI4 to NI8 card swap issue
bright676
Nov 2012
va
494
I thought it would a simple swap, I connected to NI4 channels to the same channels on the NI8 card and did not add any more input connections, after I did the swap it wasn't reading any of the original inputs, bear in mind I did a channel for channel swap.
I called Rockwell for support and they said the inputs need to be enabled but due to time constraints it was quicker to forget the 8 channel upgrade and just put in a new NI4 card.
Well with connecting channel to channel I thought it would be straight forward but apparently its not.
A/B talked about block transfers and I know nutting about them, but they are all ready there.
Any help would be appreciated. Thank you.
You have to do a block transfer write to an analog input module to provide configuration information before you can get an appropriate block transfer read of the data from the module. Your block transfers must be updated to match the different module.
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
122
I have a project to setup base programs across multiple PLC platforms that can be used for Modbus communications to various sensors that have...
125
System Details: We use hot redundant Modicon Quantum PLC with dual redundant communication having Remote IO racks (using CRP + CRA cards and...
779
Hi Folks, We have this M580's configured as hotstandby and is curious if it is possible to monitor the modules on the remote racks. Unity pro...
1,592
I have a remote rack with a 1747-ASB. It has a 1746-NI4 in it and I need to replace it with a 1746-NI8 to get some more analog inputs. I have...
1,134
