551 no connection to plc with address 2
SLaubach
Apr 2002
PA
152
hello i am having problems with an OP37 showing error 551 intermittently and then the OP will shut down and restart automatically. Did anyone ever run into this issue before?
thanks scott
#551 AS address 2
not possible
Losing communication, any OP that is programmed when powere looks for a connection, if it doesnt find one it will give that message. Try another OP if you have 1 and see if it does it. If it does WORK the comm port or communications for the plc or the cable has a problem, if it doesnt then that OP more then likely has a problem
Thanks Ron
i threw in an old OP37 that was supposed to be sent out for touchpad membrane repairs 3 months ago....thank god for our inept purchasing people!
I am glad it worked for you, I have read my post over and over and I know it doesnt sound right, but I reckon you got the gist of it.
OP3 #551 AS address 2 not possible
I have three machines are similar and work with op3 which one op3 is defected.
I bring new one and after install it and after connected with PLC 200 is appear this massage #551 AS address 2 not possible please help me for this problem
#551 AS address 2
not possible
Vintage L551 - series C - FRN 5. SDN is same vintage. Replacing old 1336 with PF755, which so far hasn't been much of an issue on the...
1,336
Hello I have an Allen-Bradley l551 Ser. B The plc faults out with a solid red LED, but when I remove battery it's good. I did the reset, ground to...
1,850
I have a project for school to let 2 Beckhoff 6551 wireless data modules to communicate. Problem is one is always going out of run when I go from...
2,655
Hey there wondering if anyone can help? I have 6x 1747-L551 processors and about a month ago I connected to them all by serial port and null...
1,970
Will this card double as an Allen Bradley PCMK card ? If not I'm going to sell it. It has never been used and in the original box.
1,892
