575v or 600v to 24vdc
rQx
Oct 2010
Trelleborg
1,051
I've been searching for a power supply that is rated 575 or 600v to 24vdc. I cant seem to find any and I would also want it to be a known large brand. Since I cant find any I wonder how this is solved?
/Tim
It doesn't exist!!!!
Not in North America anyway that is CSA and UL recognized.
Iv been searching far and wide. The highest I can find is 550, its made for the 460VAC aspect.
I so wish that one would come available, it would save me putting xfmrs in my 575/600 builds.
What about a small transformer that would take the 575/600 to 120, and then use a power supply that provides 24 VDC with a 120 VAC input.
The amount of isolation needed vs. the demand (or lack there of) probably means stepping down with a transformer to 120 or 240 is your best bet. I could make an argument that for safety reasons that's a better way to go anyway.
Check AUTOMATION DIRECT.
RHINO PSB Series
DIN-Rail mount basic DC voltage power supplies offer high performance and reliability at lower cost.
  • 12VDC, 24VDC, 48VDC outputs, 15 to 960 W
  • 48VDC output, 480W
  • Universal input voltage, 85-264 VAC / 120-375 VDC single phase or 320-600 VAC 3-phase input
  • Overload, overvoltage and thermal protection
  • (5) 24VDC output, single phase input models for Class 1, Div 2 hazardous locations
  • (2) 48VDC output single phase input models
  • 24VDC (adjustable), 40A (960W)
Modern 3-ph AC to DC PSU are as safe as if you go via a transfomer. Just chose a PSU that has galvanic isolation and "safety extra low voltage" rated which most modern PSUs have.
Nice.
Iv been badgering my Eaton supplier for something like this but he never found a suitable part number.
The rhino looks pretty good to. Its priced lower. Hopefully its durable enough to handle the tasks though.
I do not have any experience with them just did some searching found those on grainger. That is the smaller 60W version looks like that series goes up to 960W output.
Nice.
Iv already sent this part number to my supplier for pricing. It also comes in a 120 Watt version that I'm looking for!
I was thinking more along the lines of being able to separate the 600VAC lines from the 24VDC system. If you use a transformer to bring the 600VAC down to 120VAC you could then run the 120VAC lines to a separate panel where the 24VDC system lives.
Hi all, I have a client that is trying to save money on generation costs. They have decided to run their generator on different speeds and so our...
3,734
Hi all. I am needing to spec out an AC Variable Frequence Drive to go on a machine destined for Ontario, Canada. The industrial power in Canada...
20
7,792
Hi everyone: we have Baumuller AC drive BM4463 300A 160KW, it drives Baumuller AC motor DST2-315BO54W-020-5-A (90KW;RPM 200; 365V; 215A;83Hz)...
363
Customer wants to put 3 phase transformer beetwen 600V VFD and 220v motor. Is it going to work?
22
8,510
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
422
