6ES5 095-8MB02 Connected to S7 315-2DP
waynedennison
Jul 2007
sligo
Hi all,
I need to connect a S5 095-8MB02 cpu (Sinec L2) to a S7 315-2DP (Profibus DP) for transfer of analog signals between the two. Does any1 no of any Sinec L2 to Profibus DP Convertors or anything that would allow me to transfer data between them.
Thanks for the help.....
6ESS5 095-8MB02 CPU is capable to communicate with other profibus devices via it's built in Sinec L2 interface (in fact it's Profibus interface). Unfortunatelly this S5 CPU doesn't provide DP Master or DP Slave functionality. For connection from S7-300 side an CP342-5 will be required since you have to use S5 compatibile communication (FDL).
Yes you are correct, Siemens have given me the same answer. However there are already devices communicating on the S5 side and i am wondering can i connect the S7 using FDL onto the same connection without causing problems for the devices already connected. Do you no does the built in Sinec L2 of the CPU only communicate in FDL. If that is so then i should be able to add in the S7.
Hi, I'm looking for standart function blocs SIEMENS S5 6ES5 840-7SG01 for IP262 and standart function blocs SIEMENS S5 6ES5 840-4BC21 for PID CPU 103
1,209
Hello Everyone, i have a machine which has a module "6ES5 262-8MA13" installed Recently this module got defective. now i want to replace it with...
1,427
Hello First...alot of thanks to everyone help in this great forum... Second: I wanna program siemens s5 cpu 6ES5-922-1AA11... what I need for...
2,304
Hello I searched for datasheet "manual" for this module : 6ES5 250 1AA11 ,, and I didn't find anything... Where can I find pdf for this module...
1,819
hello, I have a machine tool HS, CPU-6ES5-921-3W14 (1982) sinumerik is defective, I have in stock the simatics 135U CPU 6ES5-922-3UA11 (1991), I...
1,342
