A/B custom AOI Question
toddp65
Aug 2014
Florence, Ky
282
So I had previously downloaded this AOI for Rs5000 (etc.) for buffering out a mildly erratic analog input (temperature) I added all of my variables and such and it seems to be working to buffer the input. As far as I can tell, the output is the Average, or the result of the time average logic.
Now what can I do with it? I don't see any way to use the number to send it to my HMI or to use it in temperature monitoring in one of my previous EQU instructions to control a valve. It doesn't seem to have a tag; when you pull in into a move instruction it's just a number. Thoughts on this? The info regarding what to do is vague. Maybe I need an alternative?
What do you mean by 'pull it into a move instruction'?
You should be able to address it as an element within the AOI tag; in the example shown you would use Temp_Buffer.Average
I guess I mean if you're going to grab a tag and move it to an array or move it to a timer PRE or something (just examples).
Ok great...I wasn't on the proper mindset to use the element preceded by the tag name and a decimal point. I did that, as you mentioned, and the tag is available and I can use it. I wasn't acquainted with grabbing those elements and how to modify them for use in the logic.
You may also be able to set it to output it directly into a tag… I don't deal with AOI very often but I believe that should work.
So you would create a tag of suitable type (looks like a Real) and enter it in where the AOI is currently showing the average value. The AOI will then output the value to that tag.
Is there a way to customize the display of an instance of a ControlLogix AOI? For example, if an AOI was written to have either a high or low...
1,942
Good day! I am working on a project at our campus to integrate fleet vehicle chargers with load management so we don't overwhelm our service. The...
37
3,873
I imported a customised shape into the project, but I don't know how to actually add into on to a specific HMI screen. Do I use the Graphics menu...
672
I'm testing the ability to make a custom ActiveX control for PVP7 applications to be able to write data out in an XML format. With my simple...
687
I am having difficulty finding documentation or examples on integrating Visual Studio with iX Developer in order to develop custom objects...
550
