A-B HSC programming problems
Robotroc
Sep 2011
Bucharest
46
Hy guys,
I have a problem can you help me ? Well .. i have an CompactLogix L45 processor and a HSC module but i don't know how tu use de Z input. In the datasheet of the module say when Z=1 the counter goes to HOLD mode. Can somebody explain to me how can i make the Z=1 ? Can i put from my RsLogix 5000 software the InputZ = 1 ? I have an Allen Bradley encoder too.
I whant to make a counter that counts for example ..1 2 3 4 5 an now to put Z=1 to hold the 5 value on stand by and after to put the Z=0 to continue counting.
Regards,
If u can help me i am waiting tour message in private or on in this thread.
Yes that i know but i what to know how can i look up the encoder pulses when i whant and unlook them after some time. Is that possible ? I whant to look up the counter after 12 complete rotations and relase them after 1 min.
Thank's
Yes but i want when i count for example 1, 2, 3, 4, 5, when i put on hold ( Z=1 ) i whant to stay in 5 value and when a release hold ( Z= 0 )i want to continue counting from 5 and after 6, 7, 8, 9, etc .
1,2,3,4,5,hold hold hold 6,7,8,9, etc
If it is possible software can u give me and example please ? I want to make this from RsLogix5000 only without having to tie INPUT Z to the HSC. I hope I was more explicit now
Thanks,
Once again Z comes from encoder and can not be manipulated. What you need is a counter and when that counter is done then you can do whatever you want. have you read 1769-HSC manual ??
Yes, I read but somehow still fail to use when I want the HOLD (not once per revolution). I still have problems but I think are going to solve them. I think I need to find a solution to activate the Z input of another source of external 24V when I want.
Thank's a lot
Hello, So I have a Micro850 PLC with a 2080-MOT-HSC Plug-In module, and i'll be using this for an encoder. I think it was version 11 in CCW...
1,992
Hello: I use the 1769-HSC module in the compactlogix system, the cpu1769-L32E, now I use the 1769-hsc output, but i can't configuration and...
1,694
This is my first project using Allen Bradley's new(er) CCW... and I'm stuck. Here's the application: This is a small plastic extrusion machine...
5,044
Although I am not new at AB programming, I am new programming with high speed counters to create an analog output for drive speed control. If...
4,683
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
64
