A-B point to point cable
jseavers
Oct 2005
Central WI
112
Does anyone know the part # for Allen Bradleys Point to Point cable? This cable is used for panelbuilder 32 to panelview Rs232. Thanks!!
Any straight thru RS232 cable ( 9 Pin) will do, For all standard PV.
Except the Micro 300 ( it takes a null-modem RS232 cable ( 9 pin)
Whats the Cat No. of your PV
Anyone know off the top what the maximum cable length should be between a compact logix controller and some point I/O? I have 10 meters in my...
1,584
Hi all, I am planning on installing a AB 1794 point IO system using the ethernet 1794-AENT and 7 IO modules connected to a compactlogix L35E. The...
5,149
Hi, I have some problem with View Point which I'm using to manual control of conveyors. On begin when in network was only PLC and HMI View Point...
79
I have a bunch of tags in Historian/VantagePoint that off by one decimal point. I looked into the HMI displaying the same number, and the HMI is...
117
Good morning, I have a Emerson/GE PLC with Cimplicity SCADA. I need to export data of a specific point/object to a CSV file and load the CSV file...
289
