A Famous Question
crying_baby
Mar 2005
earth
112
Y DOES MY THIRD timer(THE VERY LAST 1) OOPS sry for the caps
y does my last timer count backwards instead of forward in my CW ladder?
i havent finish it yet but the very last counter got me busy and not to go on..
plz advice me is there something wrong on my ladder?
thank u for ur time and attention!!
my lader is as follow
¦PROGRM ¦TABLES ¦STATUS ¦       ¦       ¦       ¦SETUP  ¦FOLDER ¦UTILTY ¦PRINT
1insert 2edit 3modify 4search 5 6 7option 8goto 9more 10zoom
[ START OF PROGRAM LOGIC ]
START STOP %M0002
%M0002 ¦
%M0002 SYST_ON
START CPSENSR STOP CAR_OK
START CPSENSR STOP +-----+ %M0001
--¦ +-----¦ +-----¦/+---¦ONDTR+-------------------------------------------( )--
¦0.10s¦
STOP ¦ ¦
--¦ +-------------------¦R ¦
CPSENSR¦ ¦ ¦
--¦/+--+ CONST -¦PV ¦
+00150 ¦ ¦
%R0001
+00732
STOP CPSENSR %M0001 %M0006 SOAPWTR
STOP CPSENSR SOAPWTR +-----+ %M0006
--¦/+-----¦ +-----¦ +---¦ONDTR+-------------------------------------------( )--
¦0.10s¦
STOP ¦ ¦
CONST -¦PV ¦
+00100 ¦ ¦
%R0002
+00582
STOP %M0006 %M0006 RINSWTR
STOP CPSENSR RINSWTR +-----+ %M0006
¦0.10s¦
STOP ¦ ¦
CONST -¦PV ¦
+00060 ¦ ¦
%R0003
-15804
[ END OF PROGRAM LOGIC ]
In S7 (I know you are not using S7, but I'm assuming it may be the same), when you go online to view an on-delay timer. It shows it counting down until it times out. The time it takes will still be correct, but its just the way the sofware illustrates it.
Looking at your code, it doesn't look like it matters whether the timer counts up or down as long as it takes the required amount of time to time-out.
If I've understood your question correctly, maybe this is the source of your confusion??
Cheers
JT :)
Just re-read this and your other question....
I didn't see the values below the timers before...
%R0001 = +732 %R0002 = +582 %R0003 = -15804
If %R0003 is holding an integer, is it possible that somewhere else in your code you have set the most significant bit of %R0003 ??
Have you tried a different address ie. %R0010 to see what happens?
Cheers
JT
You have overlapped your timer registers. In the Series 90 PLCs, each timer takes three consecutive %R addresses. Your first timer actually uses %R001, %R002, and %R003. The second timer uses %R002, %R003, and %R004. The third timer uses %R003, %R004, and %R005. You can see that they are interfering with each other.
Change your second timer to %R004 and your third timer to %R007 and the problem will go away.
hello, im having troubvle with the very last timer counter that keep counting backwoard instead of forward. can some1 help me point where is my...
2,221
Hi, I would like to know what are the PLC/DCS/SCADA brands that are widely used in CANADA. It would be great if there is some statistics. Thank...
1,815
hi all maybe its a lame question but i'd like to know anyway what is the worlds most famous PLC? i think its siemens but is this also the best...
136
27,469
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
169
