Hey everyone,
Ok, your ideas are all pretty good. A couple of things here that I may have been vauge on.
1)The machines feeding the Fill Stations are fixed. The part made on each machine changes. Each Fill Station can be used at any machine.
2)The function of each Fill Station is the same for each machine. The data written to the RFID is a variable.
3)When a box is filled, I will receive a done bit from the machine and send the box onto a trunkline conveyor.
4)The HMI Station will need to create and send the data to the RFID. (I will make a form on the HMI to create work orders).
5)The boxes will terminate at a common location where the tags will be read and displayed on the HMI. The SCADA system will log and save the data.
Jesper, by looking at your layout, you have the HMI talking directly to the PLC. Ok, that's no trick. Are you suggesting then that the PLC will translate the RFID info and direct it to the right write head? Or am I missing something here? There is no local HMI. No need for one.
I haven't ruled out wireless. Lets just say it's impractical.
Terry, I guess it would depend on your definition of high speed is. I could (theroretically) have 13 boxes waiting for data to be written to their tags and transfer onto the trunkline.
The system I am proposing would need to be able to understand that when I move one fill station to another machine, it's RFID address and PLC address stay consistant with the information being sent from the HMI. Now if I give every Fill station a unique address, then the operator will need to know that fill station #5 is now on machine #12 so he can make sure the RFID info is valid. This is what I'm trying to avoid. The less the operator needs to think about what is where, the easier it will be to set up the system.
Now Profibus and devicenet, in a trunkline type setup will work as described. But I think so will Canbus. (If distance isn't a factor). And Canbus would be a lot less expensive. I'll be going over hardware with my vendors next week. I'll tell you where I end up and let you guys shot holes in it.
Hey Norm, I just talked with Chris. We'll be in touch after you get back. Have fun.
Tim R
Tim R
