Hi. I have a AB 1336 Drive that’s been running fine for years is now getting "Over current" faults periodically. The motor is driving a rack and pinion. Not sure what the problem can be. There is an encoder on the shaft and a resolver on the motor. Can that be the issue (bad component)? Or maybe the drive is bad. Where should I start? Appreciate your response.
