AB 1734-IK/C Programming
jvjr
Oct 2008
PA.
96
Does anyone have a basic example ladder program
on how to get an Allen-Bradley 1734-IK/C Encoder
module up and counting?
I have been trying to find an example but it's a
no go so far.
Hi gclshort,
Thank you for the link to the manual. I never worked with this particular module and the hardware is at a customer's site several hundred miles away. I am writing the code then plan to go to the facility and download it.
what I am actually looking for is a basic ladder logic example for reference. General displaying how the functions enable count, reset count and preset load work.That should be enough to start.
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
69
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
739
I am trying to use the 4-20 mA signals from a device whose user manual says that it outputs "isolated 4-20 mA". I only have spare PLC inputs in a...
245
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
358
Hi all, This is my first time working with a 1734-IE2C analog module. I am tasked with wiring the flow meter into the analog card and the OEM is...
176
