AB 1747 PIC/AIC + DRIVER will not run.
dataglyph
Feb 2003
Toronto, Ontario
I am using linx lite and have no problems configuring drivers and running them except for 1747 PIC/AIC + DRIVER. The odd thing is that in the config window the startup, start and stop switches will not highlight. This is not the case with 232 devices, or ethernet drivers. I am using a USB/SERIAL adapter with the PIC converter, and have configured the driver with the service off and the application running. As well I have enabled reserved for this com port only, and configured all 4 ports in device manager individually for this device, but to no avail. Has anyone had this problem before, and what was done to correct it?
USB + PIC = No Comms...
That's the heart of you problem. The PIC just won't work with USB to serial adapters... :(
You'll either need a computer with a 'real' COM port, or purchase AB's 1747-UIC USB adapter.
beerchug
-Eric
Hello, I am running Windows XP SP2 and Rslinx does not have the 1747 PIC AIC+ driver available. Not showing up on driver list/selections. Is...
4,081
Let me start off by saying I know I need to get a 1747-UIC, but I can't get one in for a couple days and I'm working on something time sensitive...
9,495
I installed RSlinx Lite to a new laptop running on Win 7 and when i tried setting up the drivers, i noticed that there was no driver for...
19,805
Is there no compatible solution for this? I feel like I am in the stone ages here. Does AB think comp manufacturers are going to start putting...
29
9,600
good afternoon all I had to pull out the old 1747-pic module my question it has a 25 pin connection I need to go to a 9 pin connection do pin 2...
1,595
