AB 1756-DNB Idle/Run Mode
LangMichael
Aug 2013
Wels
Hi guys,
I´m configuring a AB Guarlogix with Safetypartner and the 1756 DeviceNet-Scanner!
Using:
- 3x 1791DS-IB8X
- 1x 1791DS-IB16
- RSLogix 5000
When I go to "Controller Tags", the Input values of the modules are presented corret.
But I can´t set any Output, or force them. (I can, but the real output won´t get high)
After some reading, I found out, that this might be, because the scanner is in Idle mode and there, Outputs are not controlled.
My problem now is: If i set Local:3:O.CommandRegister.Run nothing happens. But the scanner reacts, for example if I set ....Register.Reset!
Has anybody an idea, what the problem could be?
I would be very thankfull for any information!!
thanks for the help
I´m with stupid -> Me
After a few hours I thought I could try to switch the controller to RUN mode and this was the solution to my problem!
There isn´t any document, that says that I have to place the controller in run mode to get the Scanner in run mode! But now I can go on!!
Make sure the DeviceNet is always put into run mode when the processor runs by putting an unconditional rung with OTE Local:3:O.CommandRegister.Run as the first rung of your Main Program in the Continuous Task.
If the processor goes out of Run mode, all non-retentive outputs are turned off, including the DeviceNet "Run" command. When the processor re-enters Run Mode, the rung will re-enable Run Mode on the DeviceNet.
NOTE : Inputs are not always active in "Idle" mode... Some devices are, some are not. So debugging in Program Mode is not really valid for DeviceNet inputs.
hey! I have this 1756-DNB card going IDLE for 2-3 seconds and then back to run. It happens every 15 minutes or so...The only thing we've noticed...
1,998
I'm trying to find out the conditions that could cause a DNB to go to IDLE mode on it's own. We have a project that has a DNB in a remote...
2,082
Hi good day PLC Talk Community. Can somebody please shed light on 1756-DNB Diagnotic Counters and what they mean. DNB Scanner Diagnostic...
579
Hello, PLCS.net guys. Currently I'm making the safety communication on 1756-DNB to DX200 Yaskawa contoller. I made the setting and assigned the...
629
Numatics devicenet module G2-2 is replaced with new unit and address is configured from address 63 to address 1. Encountered error E#77 for Node 1...
1,039
