AB 1783-NATR vs MOXA NAT-102
chiefjimbo
Jul 2023
Baltimore, MD
We've been using Allen-Bradley's 1783-NATR and find it is easy enough to work with. Unfortunately, it only allows 5 ports to be opened per IP address/Device that is mapped from the private side. The limitation of 5 prevents us from connecting to some vision systems and robot platforms as some vendors require 10-15 ports to communicate.
Is the MOXA NAT-102 any better? It looks much more feature rich but it isn't clear if it has an upper bound on TCP/UDP ports you can open for each IP address.
I really like them; compared to the 1783-NATR, it is less of a dedicated NAT and more like a little layer 3 aware switch and comes with a firewall. The firewall has a limit of 32 rules, which is what I think you are asking about. You can configure the firewall for ranges of IP addresses or ranges of ports, or both.
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
247
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
432
I am trying to communicating with other PLCs on a public network from a CompactLogix PLC on a private network. I have installed at 1783-NATR...
556
Hello, I'm seeing some interesting behavior with my NATR connections on FTLinx. 2 separate cases are showing the same problem: The first NATR...
622
Hello, I have been trying to set up a NATR with 3 connections, I am able to ping the public IP of the NATR itself off of my network, but nothing...
680
