Ab Hardware Understanding
Nelliyan
Sep 2011
90
i am just studying the Ab plc rslogix 5000 software...
Now i had developed the PLC as controll logix & created a new Di module in Backplane as 1756_IV16/A ,i just added 16 pin inp,, but in the Controller tags its showing 32 tags as data...
What are the other 16 data..C img for details
Regards,
Nelliyan.G
The first 16 booleans correspond to your inputs. The reason there are 32 is because the data format is Double Integer. Just ignore bits 16-31. There are 32 Point input cards that use all of the bits. I'm guess A-B just used the DINT format for all input cards to keep things simpler and more uniform.
can some give me idea for commnicating rs logix 5000 & rs view me via 5000 emulator i achived communication between 5000 & rs linx... how between linx & rs view me
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
201
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
471
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
163
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
135
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
599
