AB HSCE Wiring An Encoder
Secpcb
Jan 2015
Detroit, Michigan
136
I am rebuilding a line with 2 conveyor sections, that the process speed is calculated from a rate signal from 2 high-speed counter modules. The PLC that was in the line, that I have the schematic for, was a Mitsubishi and I am installing a SLC5/04 with 2) 1746-HSCE cards.
The manual shows wiring of a variety of encoders, with A, B & Z channels. However these encoders are only 2 channel (A & B per the Mitsubishi wiring) but the AB manual does not show this option. Even the appendix for a differential encoder mentions 3 channels.
Does anyone know how to wire a 2 channel encoder to a HSCE card? Or is it even possible?
I hope this can be done on a SLC, as I have no practical experience, or the software, for Mitsubishi.
Sure you can. The A and B pulses are for direction. The Z is a input that can be used for a reset of the counter. So depending on how you set up the Counter Reset Control will determine if you need a Z input or not.
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,526
Hello Again Last week I post a topic on hi speed counter advice. Thanks to all who answered. I have decided to us allen bradleys hsce module...
2,187
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on...
364
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,029
Hi there, I have a machine where was a servo with extra encoder. That encoder had resolution 100ppr/5V. We did replace complet servopack (...
951
