AB logo switch on PV Plus
bigrthanur
Mar 2007
Ohio
85
A year or so ago I came across an exe file that would allow you to put your own logo in place of the AB one on the screen saver(the one that bounces the AB logo around) but I cant find it anywhere, does anyone have the txt file I can get or the code?
The file you're looking for is just a batch file that replaces the existing "ssfloat.bmp" file with your custom one.
All the details about this, including resolution and transparency and the batch files, are in RA Knowledgebase Article ID # 28335 (TechConnect required).
An excerpt from that Knowledgebase article:
Changing the Default Screen Saver Bitmap to a Custom Bitmap
Create a file on a desktop or laptop computer named autorun.bat.
In the file, place the following three lines, which vary according to the device you're using:
If Using a Compact Flash Card
pause
If Using a USB Memory Stick
pause
Replace oem.bmp with the name of the custom bitmap.
Place the file autorun.bat on a Compact Flash card.
Insert Compact Flash card into the external slot on the terminal (if using a USB memory stick instead, the autorun.bat file will not run automatically).
Make sure the files are copied correctly by observing the Copied 1 file(s) message.
After completing the procedure, close the window by pressing a key or tapping on the X in the upper right.
The autorun.bat will not fire on insertion of the USB. Manually cycle power with the USB storage device in the slot to fire the autorun.bat.
NOTE: For PV+ 400 and 600 units, reset the terminal so the bitmap will be properly loaded into memory.
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
313
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
379
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,088
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
1,009
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,058
