AB Micro 1000 clear fault
jimtech67
Jun 2002
New Jersey
507
[font=&quot]Is there a way to clear a fault in an AB Micro 1000 without hooking up a laptop and using RS Logix. Cycling power would not clear the fault[/font]
No. No keyswitch. Go online and find out what the error is. Look at Processor Status "Math" and "Errors" tabs. There is probably a programmatic way to prevent the error or reset it.
Edit: There IS a way to cause faults to be cleared automatically:
RUN Always S:1/12
Setting this bit causes the controller to enter the REM Run mode if an unexpected reset occurs, regardless of the mode that the controller was in before the reset occurred. This bit overrides any faults existing at power down.
RSLogix 500 - Copyright Rockwell Software 2000, 2001, 2002
I would NOT do this until I found the source of the error and ruled out all other possible solutions.
incase you have a microview attached to this plc, you could switch the controller to program mode and then again to run mode. THis resets the fault ...
The fault was the following: ( A RET instruction was detected in file 2 ). I found no reason for this fault because there is not RET instruction in file 2. Very strange.
The machine was running for years with on problem then this happened. I cleared the fault and all is well so far.
Do you have any nested subroutine calls?
Or worse, recursive subroutine calls, such as where SBR 5 calls SBR 6 and SBR 6 then calls SBR 5 again, which then calls 6 again?
In addition to Alarics accurate response (and one that makes me think he's overrun the stack in a PLC once or twice), how is your power?
Transient spikes and glitches can definately cause a temporary program corruption.
The program is nothing fancy 20 lines to stop and start 3 drives. No subroutines. My guess is a power power spike or something like that. I was told there has been history of dirty power at the plant. Thanks for all the respones
I have a micrologix 1000 that I cannot seem to connect to. I don't think the com board is bad but I just cannot seem to connect. I am using Links...
2,513
Hi all So I made this PLC learner box with 6 toggle switches and some push buttons I have it all wired up and all set. However I am having a...
1,440
Hi everyone first day first post. I have a question? Can someone tell me the difference between a micro logic 1000 L10BWA & 1000 BXB? I know the...
1,311
im using a micro logix 1000 and it has 20 inputs and outputs on it but when i go onto rslogic 500 it only shows 16 how do i use the last four...
2,184
does anyone have any idea where I could get a used micro Logix 1000 trainer used? Or could this be a dumb idea to pursue I look on the net and I...
39
11,298
