AB Micrologix 1000 timer question
weilerot
Nov 2004
19
I have an AB Micrologix 1000. It has a 1K memory. The literature says it has 40 internal timers. Does anyone know how they come up with this value? I was taught that this PLC has approximately 512 words. Based on each timer using two words then I should have 256 internal timers. Where am I going wrong?
The ML1K is Allen Bradley's bottom dweller. Unlike other AB PLCs which have user configurable data tables, all of the data tables of this PLC are fixed in size. Each timer occupies 3 16 bit words in memory. This is the timer data size, not counting the memory occupied by the program which holds the timer instruction itself.
In a PLC when you see that it has 1K of memory, that is 1K words of memory, or 2048 bytes. In addition to 40 timers, the ML1K also has 32 words of bit files, 32 counters (3 words each), 16 instruciton control elements, 3 words each, and 105 integers, and 15 program files, leaving about 600 words for the user program - which is quite a bit as PLC programs are relatively compact.
The bottom dweller just crossed the $400.00 mark for me $408.00 to be exact. For the L32AWA. I wonder if the are jacking up the price to drive customers to other controllers so they can obsolete it?
Next time try EBay first. There it is often under $100 and sometimes under $50.
The 1761-L10BXB lists for $99. Much less I/O but this is their cheapest PLC.
If I need a brick, I never buy ML1Ks. For just a few bucks more you can get a ML1200 and get a whole lot more functionality.
:( I have a problem with a timer that does not time out but keeps cycling. I have this timer's N.C. Done bit in the rung as well the next timer I...
2,133
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
143
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,261
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
989
Hello All I am trying to convert a ML1000 program for use in a ML1400. I didn't create the original program & documentation is non existent...
4,416
