AB: Micrologix 1100 Fault LED Solid
Supanut-Tung
Oct 2015
Bangkok
Dear All,
I've a problem with MicroLogix 1100 fault LED solid. I'm trying to upload file from this device. But I can't to go online with Rs-232 (RSLink by using DF-1 does not found the PLC). The LCD monitor doesn't show anything. In the manual explain about this fault is "Processor Hardware Error". Please help me to find a solution to upload file. Thank you.
ML Fault
This usually happens if you are using the internal DC power supply of the ML to power your devices(e.g sensors, switches..etc), it happens if you have a short circuit in one of these devices.
To clear the fault you should have a mean to go on line with your processor & go to the controller properties & from there you clear the MAJOR FAULT.
Cheers
Hagos
On a Micrologix 1100, a card failed. After replacing the card, there is a fault 0187H. What does this fault mean and is there a way to clear the...
1,471
Hello. I have recently got a micrologix 1100 from allen bradley for my home projekts. I have tried to download a program to it but when i had...
4,843
Please I have a Micrologix 1000 that keeps blinking a red fault light each time the machine is put on. What should I do to clear this fault?
4,034
ML 1100 is going to fault with code 0020h.What will be the reason.How we can solve it.
7,309
my micrologix 1100 just went into a blinking fault state when i tried uploading a different program with a different ip address. the fault code is...
19,880
