Micrologix 1100 fault code.
As I'm sure you read in the Help file, error code 0020h indicates that a minor error occurred.
These are usually things like divide-by-zero or a negative timer preset.
The error will be indicated in one of the bits in the lower half of Status Word S:5.
Unfortunately the MicroLogix controllers can't tell you exactly what File and Rung created the error condition, so you have to trap it programmatically.
There are some good examples of doing this in the RA Knowledgebase, such as in Answer ID 31778 (TechConnect Required).
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/31778
ML 1100 is connected to a lantronix 485/TCP converter.I checked with removing 485 cable (1763-NC01) then everything working fine.No fault occured in ML 1100 so what will be the issue.before error code was 0020h.
On a Micrologix 1100, a card failed. After replacing the card, there is a fault 0187H. What does this fault mean and is there a way to clear the...
1,472
Hello. I have recently got a micrologix 1100 from allen bradley for my home projekts. I have tried to download a program to it but when i had...
4,847
Dear All, I've a problem with MicroLogix 1100 fault LED solid. I'm trying to upload file from this device. But I can't to go online with Rs-232...
2,713
Please I have a Micrologix 1000 that keeps blinking a red fault light each time the machine is put on. What should I do to clear this fault?
4,035
my micrologix 1100 just went into a blinking fault state when i tried uploading a different program with a different ip address. the fault code is...
19,881
