AB ML1100 connected to GE quickpanel
Robfig80
Jun 2016
Hillsborough
Recently I had a steady fault light on my ML and a bunch of question marks on all the virtual buttons on my HMI. I spoke with programmer that did the start up on the equipment and both agreed that the steady light meant I had some sort of hardware failure on PLC. He sent me a new unit uploaded with supposed current program but when we replaced unit fault light was gone but question marks remain and unit is still off-line
Welcome to the Forum!
The most likely thing is the Communication Settings in the PLC.
How are you communicating to the PLC from the QuickPanel?
If it is Serial, you need to find out what Baud Rate, Stop Bits, and Parity etc that it expects, and set the PLC to match.
Stu....
Will I need the GE software for the HMI or willi be able to view settings without PC connection. Reason why I ask is because I do not have the software to connect to screen I only have the AB software. Is there free download or trial version I could perhaps use?
Also should the new unit with the supposed most recent program have carried over all those parameters as well?
Not necessarily, it usually asks you if you want to overwrite the Communications Channel Setting when you do a Download, and they may have said no.
Stu....
I have never used a GE QuickPanel, so I am not familiar with them. You will have to download the Manual for it, and see if there is a Menu you can get into to see the settings. Most HMIs I have used have this function. You just have to figure out what the trick is.
Stu....
If you Download the Manual, or a supplemental Manual for the QuickPanel, it should tell you the Communications Setup to use with the ML1100, or possibly a SLC, which should be similar.
Stu....
I'm looking to implement a low-cost, efficient method of communicating some integer values to an R30iB robot from a Rockwell 1100 PLC. I am not...
1,734
Hello all, I am trying to setup my MicroLogix 1100 as a modbus RTU master for a modbus network containing multiple modbus RTU slaves. I currently...
3,947
We have a machine that keeps losing its program at random intervals; sometimes 2x-3x in a shift, sometimes will go over 1wk without issue. I had a...
2,950
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,597
I have a CLX L61 and I'm trying to read from and write to a Micrologix 1100. I'm attempting to read 200 REAL elements but I'm receiving an error...
1,467
