AB PLC 5/250 to PV600
sparky64
May 2003
Newcastle upon Tyne
127
I want to install a pv600 on RIO, The plc is a 5/250 which has 4 X 5150-RS2 scanner cards.
When i tried to setup my new pb32 project i can't see the scanner card in the options list.
Is the 5/250 scanner capable of communicating to a PV600??
Thanks for any replies
Sparky
I think all you need to do is select SoftLogix. That will give you rack addresses up to octal 37, which is the limit for the 5/250.
As far as I can tell, the selection only defines rack address limits and perhaps baud rate.
Hi, I am currently challenging in a new requirement on my new project. We have delivered a project long year ago using DL-250-1 PLC+ 8 point...
1,546
I've got a print-out of old code (PLC-5/250) that I am trying to decipher. I am hung up on an expression in one of the compute blocks. The block...
3,432
Dear Experts, Attached is the photo of old MODICON A250 PLC of CPU type AEG ALU 151-1. PLC & HMI backups are available on below link...
2,960
I was wondering if there is a way to set a new path to the PLC manually in the PV+? They had me change the IP of the PLC's and of course the HMI...
2,365
I have a problem with PLC 5/250 PI. Two (dual reduandant) data concentrators have recently been "locking up" and showing red light on the...
2,141
