AB plc connection dropping
macgioo2
Oct 2009
Cambridge
98
Hi guys,
I have connected my virtual xp machine which is mounted on a windows 7 dell vostro to an allen-bradley control logix plc over ethernet. This is an old system I worked on before and was completely reliable with my previous pc.
But now its losing the connection to the plc every few minutes stating something about the data in the controller not being the same.
I have changed cables but that hasn't helped, I even put it on the network to see if something would change but still the same.
Does any one know what the problem is?
Turns out that the virtual xp machine was the problem here as when run with an actual xp machine there were no problems.
The solution was to use VMware as opposed to the virtual machine this worked fine!
I have got an Rockwell PLC 1769-L36ERMS . I have assigned a IP address to it . But every-time I Reboot the PLC it looses Communication to my PC...
61
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
329
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
463
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
256
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
241
