orangestorm87
I want to start this by saying all the following is for curiosity sake only, no real world / production ramifications come along. Inspiration came from a post in the forum talking about trying to get a PLC-2 to talk to a controllogix over ethernet.
I am looking for the official way to program a PLC2. PLC-2/20 specifically. I recently had the crazy idea to acquire old AB PLC's and try to get them talking to one another or atleast send signals to each other for a fun demo just to say I could, and I think it will be fun. So PLC-2 to a PLC-3, PLC5, SLC etc etc
So might as well start as old as I can with a PLC-2.
Reading the manual it talks about the programming port is a 15-pin socket that uses a 1772-TC Programing Panel Interconnect Cable. It says this can be used by Industrial terminals or "IBM PC-compatible" with 6201 or 6211 software. How/what kind of port on the IBM PC do you need to accept this cable? Are their drivers you need to install, I assume so being it is Datahighway.
Is there some programming interface required? I found while searching AB Datahighway interface (1770-KF2) that looks like it has a 25pin PC interface.
Does anyone who worked with PLC-2's remember how to setup the software to communicate with the PLC?
Are their any known "modern" solutions like using dosbox with 6201 or 6211?
There seems to be a few different software options. If I was to travel back to the 1980's what were people using back then? Or what software gives the most functionality when working with a PLC-2.
